pancake
The engine builder provided a dyno graph for the engine that I suspect came out of desktop dyno. Since that's all I have to go off of right now, I'm going to assume that it's good enough to ballpark from and run with it. At 1500rpm, the engine should produce better than 350 ft. lbs of torque which means that it should cruise just fine at 1500 rpm and I should try to get my cruising rpm between 1500 – 2000 rpm for the 60 – 80 mph range.
I made a little excel spreadsheet to put all of this in table form but it doesn't keep the formatting when I copy and paste. So here's the info in paragraph form..
So.. As it currently stands with the stock Saginaw transmission and 3.36:1 rear end…
From what I read, the Saginaw used in the Vettes had 2.85, 2.02, 1.35, and 1.00 ratios. Assuming a 27 inch tire, the 60 mph cruising rpm would be 2508 rpm and 80 mph would be 3345 rpm. The first gear final drive ratio is 9.58:1, which is close to the goal of a 10:1 first.
If it had an M21 with the 3.36:1 rear end…
The trans would have 2.20, 1.64, 1.27, and 1.0 ratios. Assuming a 27 inch tire, the 60 mph cruising rpm would also be 2508 rpm (1:1 4th) and the 80 mph rpm would be 3345. The first gear final drive ratio is 7.39:1, which is a good bit below the 10:1 goal.
A T56 with the 3:36 rear end…
Trans gearing for all but a few T56's is 2.66, 1.78, 1.30, 1.0, .74, .50. The 60mph cruising rpm would be 1254 and 80 mph would be 1672. The first gear final drive ratio is 8.94:1, which is better than the Muncie but still not the desired 10:1.
A T56 with 3.73 rear end would have the same gearing as above. The 60 mph cruising rpm is 1392 and 80 mph is 1857. The first gear final drive ratio is 9.92:1.
A T56 with 3.90 rear end would have the same gearing as above. The 60 mph cruising rpm is 1456 and 80 mph is 1941. The first gear final drive ratio is 10.37:1.
Comparatively, a Richmond ROD as sold by Jegs has 3.28, 2.13, 1.57, 1.23, 1.00, and .76 gear ratios. With a 3.36:1 rear end, the 60 mph rpm would be 1907 and 80 mph would be 2542. The first gear final drive ratio is 11.02.
A Richmond ROD with the ratios above and a 3.08:1 rear end would run at 1748 rpm at 60 mph and 2330 at 80 mph. The first gear final drive ratio is 10.10:1.
The Richmond has the advantage that you can call them and basically order it with what ever ratios you want. The downside is that it is expensive.
