SHAKERATTLEROLL
Has anyone used these? And if so any thoughts? Thank You
A couple points...
The oil pressure supplied by the Accusump is what you precharge the air side to. Typically for any accumulator you charge it to standard operating pressure. So you needn't fear any sudden burst of high pressure oil because it's under your control.
Next, the guys are absolutely correct that you want an electric valve to open when the ignition is on. Trouble is those Goyens are hard to find so buy it with your Accusump.
That's my experience, hope it helps...Steve
Good observation above from 69427,
We're dealing with semantics and that is an important detail. We shouldn't really be concerned about what the empty accumulator has on it, interesting as it may be.
The accumulator is an active component looking to maintain a constant pressure. If pressure spikes it's piston will retract and absorb the spike. If pressure drops it will move forward attempting to maintain the pressure. I can readily accept setting the precharge a bit above running pressure to get every last bit of oil into the engine, no question,
But in the end, you'll be best served matching the precharge in the vicinity of your running pressure.
Just trying to help...:thumbs:
