AFR with very high compression motor
Celicasaur
Member
Curious to hear what you guys think on what the ideal AFR under load at high rpm should be?
Static compression being 13.2:1, should I stick with the usual 12.8:1 AFR (N/A motor) or would it need to be slightly richer than a conventional N/A motor due to the extra compression?
Agreed. Slightly rich will give you more cushion against high cylinder temps that could lead to detonation.
