69427
- Joined
- Mar 30, 2008
- Messages
- 3,077
- Reaction score
- 38
Working on the new setup, and an issue pops into my head. It's damn tight trying to squeeze in the spare tire bucket.
The C4 tire bucket (lighter and more easily packaged) I'd planned to eventually use, and the stock tires are about 26 1/2 inches , but the mufflers are only 24 inches apart when the outlets are centered in the bodywork cutouts. If these mufflers were similar to the old ones (with the outlets in the middle rather than the outter sides) I might have had enough room. I considered moving the mufflers over an inch or so on each side but then I would have had to add an "S" bend to get back to the cutout and the baloney tips. I'm not happy with that option at the moment, so I'm just going to proceed with this configuration. In the mean time it looks like I can fit a tire behind the seats when I need to have a spare along.
Got the replacement Y pipe underneath tacked together. Took a bit of sneaking up on it to get the two 3" pipes to fit the slightly squashed 4" pipe and at the angles to point to the muffler inlets. Now I just gotta figure out where to put the sleeve/coupler between there and the mufflers so I can wiggle the assembly apart when needed.
These things better flow decently for the extra PITA that they're causing me.
