Ok now I am just gunshy and paranoid. I fired the car up today for the first time since no oil pressure. I heard no knocks, grinding , banging or any other bad mechanical noises. What I did get was some back firing out of the right side. I did not have a chance to get the motor warm because the oil filter did not seal (yet another set back). Did the backfiring occur because it had not gotten warm and I was just close enough on the timing after reinstalling the distributor to get it to crank? Something else? I did check the valves and they were all set the same as they had been for about the last year. So this tells me I don't have a valve train problem. Was it just cold and out of time?
On the oil filter issue. For some reason the filter is not sealing to the block with the old stock bypass adapter installed. Is that peice supposed to have a gasket between it and the block? I never had one before. I have tried 2 oil filters and neither has sealed. The leak is in the same location each time so that leads me to beleive that the oil filter adapter is not installed correctly somehow.
Thanks
Wade
Thanks
Wade
