73 Mike
I'll drive it someday
I'm starting to assemble my 412 SBC and would like to check the clearances. I'll probably use plastigage as I don't have a good inside mic.
I need a target clearance to order the bearings but would like to know the tolerances as well.
Based on this article among others:
http://www.chevyhiperformance.com/tech/engines_drivetrain/shortblock/4380_bearing_clearance_info/
looks like 2 thou is about optimal for both crank and rod. What says Vettemod?
Particulars:
4.185 bore
3.75 stroke
Motown block with priority main oiling
HVRP oil pump and oversize pan
Hydraulic retrofit rollers
Particulars:
4.185 bore
3.75 stroke
