Bee Jay
I got the drivers side door beam out tonight. I repeat, what a pain in the a$$. You gotta really want to do this. But I didn't break the window this time. New window should arrive tomorrow.
Bee Jay
Bee Jay
Didn't see a weight on the glass per side.
Just wondering how much of the 80 pounds is the glass.
It might make using lexan a very viable option for infrequently/not street ride.
There are a couple of outfits that already make the windows in Lexan. Speedglass http://www.percyshp.com/SpeedGlass.html is one that comes to mind and Summit sells their product as I recall. Whole set is around a grand. Apparently there have been some good mods to help keep more scratch free/resistant - Marguard(?).
I probably would NOT use the sides in a daily - the up/down might mess the lexan protective surface. Suppose you could make a sliding "port/hatch" per the Lola/Gt40/etc Lemans style to pass the patrolman your DL!
Weight saving is pretty good can be as much as 1/2 of the glass (50% - 75% lighter than glass (depending on thickness).
...............I plan to replace the heavy 78-82 rear glass with plexiglass someday. I've never seen the weight for that, but I hear it's very heavy. I replaced the passenger window last night, much easier than I thought. It only weighs 7 lbs but is much thinner than the original glass. The original glass in the drivers door is 7mm, and the new glass is 6mm.
Bee Jay
I have the window glass out of the 77 we are building, you guys want me to stick it on the scales to see how heavy it is?
Bee Jay
