DC3
Took the '73 out of town this weekend. When I arrived at my destination, I had no brake lights or hazard lights. Both were working fine the day before. Everything else worked fine. Fuses were good. Bulbs were good. Tail lamps were good. Turn signals were good. Backup lights were good. Headlights were good. Both flasher modules were good. Everything else was good. The ground connections looked good and since the turn signals worked, I didn't figure to have a grounding problem.
I pulled the wire off the brake light switch and jumpered the terminals but no luck. Apparently the brake switch is good. A buddy said the power feeds through the turn signal switch. We found a reference on the web that said if you have 12 volts to the white wire at the harmonica connector at the base of the steering column but no brake or hazard lights, that the problem was in the turn signal switch. Only problem is I didn't have 12 volts on the white wire.
I pulled the wire back off of the brake light switch and checked for voltage at both terminals but had no voltage. So apparently I had a loose connection somewhere. Had is the operative word as I took a buddy for a ride after failing to fix the problem and, while driving around, the brake and hazard lights started working again.
So, I've got an intermittent open circuit somewhere. The question is where? Is there a connector hidden somewhere I should check? The orange and white wires from the brake switch go into the harness that loops over the top of the speedometer. I really don't want to have to pull the dash for this. Any ideas?
Thanks
DC
Thanks
DC
