pcf_mark
- Joined
- Aug 22, 2008
- Messages
- 218
I have had my '60 apart about 9 years so my memory is a little dim. I took the body off the chassis to restore the car. I want to paint the car on the chassis (these things move all over the place) but I want the minimum parts on the frame to get over sprayed and dust etc crapping them up. This is the only c1 I have ever worked on so my experience is thin.
What are the minimum parts I need to install that I can not go back and put on later?
Fuel lines
Brake lines
Rad support
Front suspension is an assembly that bolts in
Rear is leaf springs and that all bolts in later
Obviously engine and transmission can go in at any time
The steering box has to be done before the engine goes in
Fuel lines
Brake lines
Rad support
