Hey Red, thank you for the number!:drink:
don`t thank me until your sure it`s a good number...
You may find that your old clutch fork is better than a new one, unless you are fortunate enough to get an original one , If you get another one compare it very closely and you may find that your original old fork is made out of thicker and stiffer metal, also you will likely find that even though they look the same they don't have the profile and the end result is , after you get it installed you will find that the clutch will not completely disengage. Best bet use your old one or get one from another car, the ones from the aftermarket definately do not do the job.
I have rebuilt mine several times since 1970. same fork as in your car, a touch of hard facing on the worn area then grind back
till flat, the spring is easily replaced, get one from an old fork in the scrap yard , one in good shape of course and rivet or bolt it on, a bit of glass beading, some paint and presto, new clutch fork.
Cool thanks for the info. But as for finding a spring in a scrap yard that's not going to happen anywhere near me , none of the scrap yards near me will have anything that old. hell I couldn't get a part for my 98 jeep there.
