sfallison
Member
Just read a thread in DC..
http://www.nrjvette.com/johdotukset/?c=d;o=d has pdf's of wiring diagrams from 1953 to 1982
I need one in colour. I have to sit down like a pre-schooler and trace any given wire with my finger
Those diagrams are ok and will do in a pinch but there are much better ones available.
Dr Rebuild sells some nice wiring diagrams, in color, and they have photos of the connectors. I have two sets; one for the 68 and one for the 70.
That guy is a jean yis.
He knows Corvettes so well because he has dissected them like a prime rib at outback, baked potatoe & bloomin onion at Outback. And too many at that.
If I don't loose weight I'm going to be embarrassed at Sebring when all I'll have on is shorts and a tshirt. I'm out of breath thinking about it.
Truthfully, they will not be done until 78, then 79, then 80, then 81 and then finally 82 will be done. Doing them in order of natural progression is the only way they can easily be done, and they are not easy to do.
Honestly, I would not wait for these 1982 if you are in a real bind. These take a long time to assemble, and must be done from real wiring harnesses - I know that all the old published GM stuff is pre production and never updated. The GM schematic are close, but that closeness is BS when trying to troubleshoot or figure what's missing.
Oh well, I'll get one from you one day. I'll be tearing into my interior soon and I'm replacing the dash harness entirely, so hopefully I won't run into too many problems. I have the GM diagrams and a laminated one from Lectric Limited and you guys though, so I should be ok :thumbs:Truthfully, they will not be done until 78, then 79, then 80, then 81 and then finally 82 will be done. Doing them in order of natural progression is the only way they can easily be done, and they are not easy to do.
