SmokeyVette
Adrenaline Junkie
I'm having a problem with my headlights.
First, the dims quit working, I thought it was the broken dimmer switch but it turns out that it wasn't. I've been driving around with brights only (I re-aimed them so they wouldn't be as bad) when I NEEDED to drive her at night, but now the brights have quit working as well.
All bulbs are good. The headlight switch is old so I bought a new one, same problems with new one installed. The parking lamps and tail lights work when the switch is pulled out but neither the dim headlights nor the brights will work.
Wrap your heads around this, the other night, before I lost them completely I turned on the headlights and nothing happened for about 30 seconds, and then they came on and worked all night.
To me, this looks like a stuck/bad relay, but I can't find a relay ANYWHERE in the headlight circuitry.
Have any of you had any problems like this before? What do you think it could be?
I swear to all that is holy, if there's a headlight relay in the console or by the heater core I'm gonna blow a gasket!:sos::suicide::club:
