Only kidding a little but..please keep a video camera handy to record the fire. Using gasoline as a degreaser is insanely dangerous.
There is an industrial cleaner in five gallon buckets at Home Depot called "### purple industrial ###" in the cleaning chemicals isle that works well also but it must be rinsed with water or it will leave a white film.
Well it ain't like you need to start the engine with a hood full of fumes, for christsakes....but you have to cut the damn oil and grease....it's about the ONLY affordable way to do it in any reasonable time frame....
only talking maybe a gallon of gas....4 bux....
two applications, done....
after that, you can blast off the left over road dust with a air jet....
or some other cleaner, if you have a pressure washer.....gasoline will not hurt a engine, water damn surely will....
:stirpot::chinese:
