Dec 8, 2010 #1 V vette Well-known member Joined Jul 18, 2008 Messages 436 Location Carlstadt If you are not getting heat as you should how do make sure the coolant is circulating in the system..? Thanks, Danny
Dec 8, 2010 #2 BBShark Garage Monkey Staff member Joined Mar 5, 2008 Messages 4,868 Location Right here Start the engine cold with the radiator cap off. When the thermostat opens, the hot water from the engine will go into the radiator and cold from radiator will go into the engine (if working properly).
