Well "Bad Luck Rat" is back!!! Most of you know the strange issues that I have had since starting this project. Well here is another one. I was getting the dash put back together after installing a fan overide switch and lights for the fans. After reinstalling everything I cranked the car for the first time in about 3 weeks. After getting it to idle I look down and the electric oil pressure guage reads 0!!!! I quickly turned the car off. Since it is an electric guage the first thing I thought was that I pulled a terminal off the guage. No Luck!! Everything was hooked up as it should be. I then went and bought a manual oil pressure guage and installed it. I pulled the distributor and used an old distributor shaft on a drill to spin the pump. I spun the pump for probably 3-5 minutes and oil never appeared in the plastic oil line and the manual guage never moved.
I have already pulled the pan and the pump. Is there a way to check the pump? Is there something that I am missing? If I really had 0 oil pressure did I do any damage in the brief run time?
The pump is a GM L88 pump and the motor has 500 miles on it at the most.
