Flushing an engine
cajos1968
Leiden, The Netherlands
My engine has been sitting around for a while. Should I flush the water cooling channels?
If so does someone have a procedure or is it just sticking a garden hose in it? Any need for additives?
depends.... if it has been sitting in a dry garage then I would just flush with water to get dirt flushed out... do you have mice that could have crawled in there ?? :lol:
If you're concerned about rust (assuming iron block) then fill it with anti freeze and let it sit for some time, then drain it.... that should take care of it...
:p I must be krazy, I imagine the upper hose left off, 5000 rpm and that mouse comes outta there like a cartoon character, :yahoo::goodnight:
