Fuel System Thoughts Please!
FUEL SYSTEM THOUGHTS PLEASE!
Not intending to Hijak this thread - just thought it sorta fits in here too.
In my typical "
Parallel-Activities", I am now starting on the Fuel system. Body is (still) off the chassis, currently building new brake lines and suspension -- so, I thought while waiting for some parts to arrive -- I'd ask about the Fuel System.
I found a pretty cool illustration and added a few questions to it so if you can help, here is the picture:
This was described as a "
Best Street/Strip Configuration." Is it Redundant - a Good Idea - or just
more money?
http://www.centuryperformance.com/ was the source for the image...
Starting at the Fuel tank.
FUEL FILTER:
I see 100 Microns used as a suggestion at the tank - and finer at the engine. I note the diagram has only a single filter - but seems logical to put a finer close the the carb. The diagram doesn't show that -- but if it makes sense - I'll add one to each line.
FUEL PUMP(s):
My 350/383 won't get to
700 HP - so, since I'm shooting for around 400-450 (with the NOS) I should be ok with maybe 100 - 150 GPH with plenty to spare?
But if running 2 pumps - should the BOTH be that size? Or, maybe smaller - knowing the extra horsepower will be with the NOS only? (This all Stands to reason -- BUT -- I am looking for advice from experienced members here on the forum)!
Seems like the second pump should be engaged only prior to the NOS?
Seems kinda like a good idea - and use the second pump only when using the NOS.
Or should I dump the idea of dual set up?
FUEL LINES:
OK. I have seen and heard the discussion between HARD LINES and BRAIDED LINES along the frame. If I go with the hard - I'll use steel, not aluminum along the frame.
So what about using steel braided from the tank to the filter and filter to the pump? Note the image has 2 pumps and dual lines from the tank.
So, if dual sets per the Illustration - what size fuel line? 3/8 ought to do it (6 AN).
This is what they recommended on the site -- but no discussion when using dual setups:
Use these figures as a fuel line sizing
Up to 250 HP = 5/16" or -04 AN
Up to 375 HP = 3/8" or -06 AN
Up to 700 HP = 1/2" or -08 AN
Up to 1000 HP = 5/8" or -10 AN
And for return (from the regulator)lines they recommended basing these on fuel pump sizing:
Up to 45 GPH = 5/16" or -04 AN
Up to 90 GPH = 3/8" or -06 AN
Up to 250 GPH = 1/2" or -08 AN
Here it would look like dual 1/2 inch lines. Or would 3/8 inch be adequate? Again hard lines along the frame and into the tank?
I've done some more thinking and the 3/8 inch line ought to be enough. Use both for feed and return. Sound about right? added edit...
REGULATOR:
Here is a diagram from HOLLEY:
Would like your thoughts and recommendations here too. Somewhere around 9 psi each - or something else for the NOS Side? I am considering a Wet System, that will be another set of questions downstream.
Or should I dump the idea of dual set up? Seems kinda like a good idea - and use the second pump only when using the NOS.
Currently, the engine has a mechanical pump mounted and steel braided line to the Edelbrok carb on the Torquer intake. Steel return line from the carb - but no regulator. Hense, I am rethinking the whole set up, and gettin ready to order some parts -- 'Start the New Year off Going for Broke!'
I am in the middle of the body-off -- so now is the best time to do all this -- before some other wild idea pops into my head!
RECOMMENDATIONS? HELP! Please.
Thanks Guys, Happy New Year!
Cheers, Jim
