DC3
Ever since I bought my '73 a couple of years ago, I've been chasing a garage gas smell.
The carburetor had issues when I bought the car so I assumed it was the problem. After a carb rebuild and dyno tune, the situation improved somewhat but the gas smell was still present.
I discovered the previous owner had eliminated the vapor canister and the vent line from the tank was open. Tracked down a new vapor canister and finally got it installed. That also helped tone down the smell but it did not completely eliminate it. As it always had been, the smell was much worse when the tank was full.
Well, a few weeks ago, my starter was acting up and I decided to replace it. I jacked up the right front of the car and began removing the old starter. Part way through that task, the smell of gas in the garage became overwhelming. Stopped what I was doing and took a walk around the car and discovered gas dripping off the driver's side muffler. Not good. It was early in the morning and I had not been driving the car so at least nothing was hot. I had gassed up the day before and so the tank was full.
The plastic gas tank vent valve/separator had failed. More than once it turned out. After removing the part I discovered one of the nipples had been epoxied back on after a prior failure and the epoxy had failed. I also discovered the valve had been remounted upside down.
After replacing the valve, my garage gas smell is now history. :yahoo:
Replacing that valve is an interesting challenge. It can be done without removing anything else but you have to work blind and with only one hand. Guys with large mitts may not make it. I cussed. A lot.
So, my advice to anyone facing the garage gas smell is to completely inspect the system from the gas cap to the carb and don't stop if you find a problem because you could have more than one issue.
DC
DC
