got bored so started welding my frame back together
got a question ...
Will a dana36 differential physically bolt up to a dana44 batwing?
I understand the top bolt difference, but what I am asking will the other bolts line up to temporarily use a dana 36 to get my suspension swap lined up?
I got the differential center mount from kidvette, so a little more welding was done, not finished on one side of it. This area will again be altered for the c4 differential mount.
Here is the issue with the c4 batwing on a c3 frame, for one the c4 batwing is to short and the c3 mounting brackets are to wide
question, it is my understanding the c3 wheel base is 98" so if I position front suspension correctly I wont even need the rear suspension from the 82 frame. All I would have to do is make a jig to establish a 98" center to center axle measurement for the wheel base to be correct. Does this sound right?
