Let me run this by you and see what you think. I pulled the pan Friday night and replaced the gasket. I did not remove the main cap and replace the seal because when I looked at it it looked dry around the crank end.
Today I reconnected my pcv and refilled the oil with 5w-30. Let the car sit in the driveway running for 10 minutes to get up to operating temp while watching for a leak at the back of the pan. Did not see one drop of oil anywhere.
Took the car for a drive and to my surprise it ran better than it had in a few months. Temps were down about 15 degrees even on a 96 degree day!
Pulled back in the driveway and looked up under the car and sure enough drip, drip drip off the very bottom of the bellhousing. Got the car in the air again and this is what I found.
Oil sprayed down passenger sidefloor pan oil on my starter and starter wires. However looking up at the rear of the pan everything was completely clean and dry. I repainted the pan while it was off so I definately would have seen something. I am looking around the intake and although I see small puddles on the side ledges it is dry just below where the rear intake seal is. I have looked at the back corners of the VC's but don't see any evidence of leaking.
Whereever it is it only leaks when under load going down the road. The leak is not near as bad as it was before the gasket change and the pcv addition so that tells me that I did releive some of the pressure by adding the valve and probably getting that Valvoline 50wt oil out..
Any ideas? Soon as it cools down I am going to pull the VC. Would a leaking VC gasket spew only under pressure?
Thanks
Wade
__________________
Thanks
Wade
__________________
