AColbe01
Active member
Reading in a different thread made me start thinking. NOT SAYING, lack of oil changes caused this! What could be done to clean this up before any parts failure?
Andy
Andy
What else would cause every pistons top compression ring to come apart? (other than a shitty engine builder) Pics to follow.I think you found the source of the miss!
As promised, here are the pics:bonkers:
This rod bearing had to be close to "spinning"
Check out the heat spots from the friction
And the #3 piston:ack:
You know, looking at the piston in the pic, it looks like the engine was run for 100,000 without an oil change! Looks like lots of sludge and varnish, and carbon build up on the parts. I'm not sure you don't just have an abused engine that had enough!!
