4 SPEED
What is the best way to jack up a C3 with sidepipes. Never thought about this until after I installed them.
Frame rail, you can jack under the door - I jack mine in the center and there doesn't seem to be an adverse reaction.
Sorry I wasn't clear.
I jacked her up plenty of times on the frame rail but now the sidepipes are lower then the framerails.
I can't fit my hydraulic jack under the sidepipes.
A arm and under diff
oh. I tried to jack mine up from the front, under the cross member, but it's too low (even with my low profile jack)... low profile on the side works because you can get up at enough of an angle to avoid hitting the pipes.
How about a block of metal or hardwood shaped to fit securely in the cradle of your floorjack. I have seen them. You typically have to slide the jack under and then put the block in place.
I'm talking under the frame rails--a block about 2 1/2" by 2 1/2" by 3" or so setting in the jack cradle so as to get up to the frame rail without crushing the side pipes.
sounds like the way to go.
your jack really gets that low to the floor?
I really don't understand why you would want to jack your C3 up on the side, like lifting both wheels off the ground, or even up forward or to the rear....why twisting the frame that much, forcing fiberglass/doors/top lids/window glass/etc into some severe twist it would never see on any normal road.....I have always lifted/raised my cars on center front or rear and supported them symmetrically.......
OK maybe on road side, one wheel gets jacked.....bur really now.....:surrender:
