Dirtbuster1
Does anyone know if the IAC motors read resistance off of the pin placement or coil placement. I ask this because my stems keep moving as they want. the originals will not move at all. If the ECM thinks that the coil is in the zero position, would it not know where the pintle is if it is moving? Should they be loctited at the correct position. Alot of this would make since if this is what is happening.
Make since?
Make since?
