DC3
I'm just finishing up the installation of Vintage Air in my '73. The AC belt was so close to the lower radiator hose that I ended up fabricating a belt/hose guard. When I test ran the engine before charging the compressor, the clearance was fine.
After charging the compressor a problem developed with the belt slapping the new guard when the compressor was engaged. Clearance was still fine when the compressor was not engaged. The belt slap was bad enough that I could not run the AC.
I then went to the absolute shortest belt I could install (NAPA/Gates 7555). I had to completely remove the compressor from its mounting bracket in order to install the belt and barely got it back on the bracket.
This gave me more clearance and initially solved the problem. But, the belt stretched a bit and the belt slap is back although minor this time.
I have an email into Vintage Air inquiring as to the possibility of another compressor bracket that would mount the compressor higher in the engine bay. I have at least 2" of room from the compressor to the hood now.
I'm wondering about the possibility of using an idler pulley under the lower part of the belt. This would allow me to run a longer belt and gain the clearance I need without having to run a different mounting bracket.
Has anyone else ran into this issue? Anyone have any ideas on fabricating a bracket to mount an idler pulley? Would a bracket using just one of the water pump bolts be okay or would it really need two mounting points? Any other suggestions?
Other info that may be relevant:
Small block w/ power steering
Inner belt - crank to water pump to alternator
Middle belt - crank to water pump to AC
Outer belt - crank to power steering pump
Mechanical fan and clutch replaced with dual Spals
Tall valve covers
Appreciate the help.
DC
Tall valve covers
DC
