the th350 is probably the best transmission to learn how to rebuild - and the rebuild kit costs peanuts
as for manual conversion... will be doing that soon - what's the big problem alluded to above?
I screwed up the post, I went from Muncie to 700 then 200 4r....the easy way...and cheep in the time frame, even today from what I read....
:smash::surrender:
i realize I wasn't clear - I'm putting a super t-10 in to replace the th350...
In the Wash DC region I spent 53 years at, the max speeds MAY reach as asstounding 80 mph for 1/2 a mile, then it's back in the soup of traffic....so the 336 rear and Muncie were fine, but on the trips here to Florida, and being here for a few months, I found the speeds were 80 at ~4k rpm to be a bit much, and this is normal speeds here....for much greater distances, this is the largest land area town in the country....the joint is SPREAD OUT....and so the need for a automatic overdrive, so I went the opposite direction, it was tricky enough to get all that shit sorted out, going to a stick from auto would be a super PIA, and more so for having to drop out all the dash to add the clutch pedal....:hissyfit:
much less the tunnel mods to dump the auto shifter and put in a stick shifter, and of course the mounts to the crossmember.....assuming it is similar to the Muncie....then get to play with the cross support and mounts....
electrical shit don't bother me too much olde tyme ET here from the vacuum tube daze yet.....:flash:
