7t2vette
My car is lowered, and I want to improve the geometry. I want to lower my rear strut mounting point at the diff. It looks like I can either fab a spacer to go between the diff and bracket to lower it (easiest) or modify the bracket itself to lower the mounting point. Is one way better/worse than the other? I could also buy a ready-made bracket from Tom's or the VBP smart strut bracket.
I've also heard of raising the diff, but I am not exactly sure how this is done. What happens to the bushings in the crossmember? Or is the diff crossmember itself modded?
I am also at the same time going to be swapping out my poly strut rods for Global West struts with rod ends. Anyone use these? I assume the plate with three holes also allows for some different positions for the struts.
http://www.globalwest.net/63-96-corvette-rear-suspension-components.html
I also need to solve a wheel hop issue that raised it's ugly head when I did the TH-400 to TKO600 swap, but that's another subject!!! :hissyfit:
