big_G
Blown Member
I feel soooo sorry for pauldana...this thread is 13 pages long. Brakes are simple. Jeezzz....http://forums.corvetteforum.com/c3-tech-performance/2566801-c3-brakes-what-to-do-next-aagghhhhh-13.html
I have no desire to read 13 pages of drivel. When I get home tonight I may PM him that if he's willing to drive it to Vegas, I'll help him figure it out.
HIS symptoms matched mine exactly, and I tried to hint that HBoost is the way to fix it.....
I just waiting for a belly laugh when he finally does the fix.....
that guy, Golden and another there....good pissing contest...:yahoo::flash:
G, TT, you guys explain my direct A to B comparo, with no recurrence of any soft pedal crapola, and my booster held vacuum just fine when the check valve was popped, saw no evidence of internal failure.....
but did notice that tough compression spring between input and output shafts...why it's there, I don't care..it just is, and I convinced that is what let the pedal to the floor, giving that shit soft squishy feel to it....
like they ALL do, it's just more accentuated on the 4 wdisc cars like the shark, I have NEVER liked any vac booster car ....I feel this HB shark now is FAR superior in pedal feel and travel, as if I actually using a solid hydraulic system now not some wimpy limp dicked setup...
so explain the huge improvement, A to B, and then the continued total reliability....over some 4?+ years now....
:bounce::clap:
:bounce::clap:
Gene..IMO when you converted to hydroboost, you inadvertently fixed your soft pedal. The vacuum booster is a solid connection, front to rear. The small spring you mention is a damper for the air valve spring, the larger one is the power piston return spring. Unless something is broken internally, the booster cannot make a soft pedal. I know I can never convince you of this...I won't try....BTW...the C-6 'Vette has perhaps the best brakes of any production sports car in the world and it has (drumroll).....vacuum assisted power brakes.
The reaction piston goes through the center of the small spring. The spring goes into the reaction body. It is there for damping, imo...So it is still a solid connection. Try pushing the pedal clevis with the output pin supported. It will not move!
G is right, it's a solid connection with a power piston, nothing more.
