I've been trying to find an appropriate forum for this and with the wealth of suspension knowledge here, this is probably the best place.
Anyway, I've been looking at doing another LS conversion since I finished my 6.0 LSx vette. I've wanted to do an aluminum 5.3 L33 in a Triumph Spitfire ( I know, not a vette). Obviously the weak spitfire rear wont hold up so I've been looking at C4 rears.
The spitfire rear is IRS with axles articulated at the diff but not the wheel, axle and wheel hub are solid. Single trailing arm, and transverse leaf springs, even the wing style body mount. Some similarities to both C3 and C4 rears. I like the C4 because of price and availability. Not sure if it's lighter than a C3, but looks to have a lot of aluminum parts.
So this will be strictly a street car. Would narrowing the halfshafts, lower control arm, and toe adjustment rod all by the same percentage be adequate? I was thinking about trying to duplicate the geometry of camber change of the spitfire, but may be overthinking the issue.
For the single to twin trailing arm arrangement, I would probably have to shorten those too, but would make them adjustable in length and frame mount location.
