Check the fuel system as mentioned and if nothing found move on to ignition. If an HEI system they can fail. If the module they will run but miss when you hit the gas pedal as it can't fire the richer mixture. Modules fail when rotor goes bad and spark goes through rotor to module. If pickup coil car usually won't run at all.
that's a new one on me - when the module fails for me it doesn't work at all.
I agree, but I have rarely had a REAL GM module fail, aftermarkets, yes.....and another cutsey little failure I caught pants down, the HEI in cap coils have crimped connectors on the solid core wire primary, they go to the + and tach/control module...Well they didn't clean the wire off the formvar it was made with, and so I caught one with no +12 on the tach side, and I"m thinking the coil is flamed, looked totally normal, soldered the connections, off and running for years.....go figger, ever since then, I solder ALL of them HEI coils, OH, and just for shits and grins, make damn sure that coil frame is actually connected to the middle/ground and don't ask me how I know this,
Ok, I fess up, I left off a ground wire, and the thing was arcing over to one of the other two connectors, and it burnt hell out of the coil/cap/etc....engine ran fine for a while, but when the crap hit the cap it started to run like shit, and when I pulled that coil cover....:suicide::sos::lol:
