NPT tread question
Belgian1979vette
Koersel/Belgium
OK, I need to tap some NPT treads. I would like to know if I would have to use a reamer first or can I just tap the drilled hole straight with the tap. If so what reamer would be a good one (size, angle etc).
Also, any good, reliable and not to expensive suppliers in the US. For these taps they charge me an arm and a leg here.
What size tap do you need and do you need it fast????
Doesn't even have to be super precise on the drill, since it's a taper it will also thread fine if you have it a little too large. I always eyeball the drill sizes for NPT (and all the other non critical fasteners BTW)
