73 Mike
I'll drive it someday
More looking for edgumucation than anything else.
Had a nice, long drive yesterday with a couple of the local vette guys. Had a great run. We met up at a friend's place and I parked on his driveway to celebrate the fact that my car currently isn't leaking anything. I had to back out of his driveway and make a couple of reverse turns to get in line and got some fairly substantial rear end clacking. I suppose it could be the half shaft U-joints and will check but the consensus opinion is that it's the pumpkin. I'm told that the first step is to drain out as much fluid as possible and replace it taking care to use the GM additive.
My question is how would the clutch packs, which presumably are the cause of the clacking, know that the car is in reverse? It isn't obvious to me how the issue would only happen in one direction.
