Bee Jay
After numerous requests, I am documenting my rear sway bar mods.
This what I did to fit the rear sway bar with my 9 1/2" wheels and 275/40-18 tires.
First, remove the sway bar, it measures 46" wide at the end link.
Second, place a 45" length of 2x4 between the end links, and cinch it in place with some come along.
Third, heat one corner of the sway bar with a torch. Take your time, it has to get red hot. When the come along slackens and the bar moves slightly your done. Let it cool slowly, then run some water over the hot corner.
Fourth, after it's cool, mount a 44" length of 2x4 between the end links, and cinch it down with the come along. Heat the opposite corner red hot, then let it cool. The sway bar will now be 44" wide at the end links.
Paint the sway bar red (makes the car faster) and mount as usual.
You need to shorten the end link stack so that it does not rub against the frame. Note the scratch mark on the frame.
Notice where the sway bar was rubbing against the tire, now there is a good 1/2" clearance space.
Next, how I modded the sway bar for 10 1/2" wheels.
Bee Jay
Bee Jay
