I did this exact same swap last year.
The power steering didn't leak, but there was alot of free play and after a tight slow corner the steering didn't self centre. I think there were issues with the control valve.
Rather than try and fix it, I bought a second-hand pitman arm and relay rod (that connects the pitman to the steering tie-rods).
I re-built my original 'box, fitted a brand new rag joint and moved the tie-rods on to the inner holes.
At first I thought I'd made a mistake, the steering was harder than I expected and the reduced ratio after being so used to the power steering seemed wrong too.
After a couple of days though I started getting used to it and then after an adrenaline filled morning driving through some wonderful winding country roads at breakneck speed I was totally won over.
The feedback from the road is better, there is absolutely zero slack or play, and I have less "stuff" to maintain, repair or crack my knuckles on.
It's probably a personal opinion, but I don't feel the increased number of turns lock to lock is a problem, in fact I occationally over reacted with the power steering, and this was something I considered prior to the swap.
I also can't think what difference there could be between a correctly set up steering box and a correctly set up rack.
And although I'll never notice the difference, there must be more power to the wheels thanks to the loss of the pump from the motor.
