Carb Doc
Just a little survey for anyone running a Solid Roller Cam on the Street, what Lifters are you using and success or failure rate???
Any truth to using solid roller cam lifters on a hydraulic roller cam for more longevity in street use?
Read that somewhere today, can't remember where, it was after one of those goalless google searches.
Something about reduced ramp rates on a hydraulic roller cam vs solid roller cam.
I think that spring rates are typically higher for solid lifters so you'd lose any benefit gained by a "softer" profile. I would think the greatest point of wear would be at the greatest point of lift.
Some of the solid roller cams assemblies can have very large spring pressures. I've seen spring pressures at 300 and more pounds. At 6000 rpm/100 rpsec a valve is being cycled at 50 times per second. Getting a 300 pound + impulse ever 50 times per second on the lifter can be very stressful.
(Is my math correct here? )
This is about my set-up...same billet Comp cam and Endure-X lifters. I just swapped cams (again) and the cam and lifters looked like new. 210 lbs. seat. Lots of stop and go traffic.CompCams has revised their solid rollers to an improved lubrication system due to failures on street-driven, low-rpm engines. Their new solid roller series, the "Endure-X™," is designed to provide lubrication at lower rpm.
This is the warning that was included with all of the previous design solid rollers:
"Remember, when using solid roller lifters, the only oiling the lifters receive is from windage created by the rotating assembly. Excessive idling or very low rpm usage may cause lack of oil supply to the lifters and cause premature wear.... This can result in extensive engine damage."
The new lifters are the "Endure-X™ Solid Roller Lifters. These feature what they call their "EDM Oil Injection™ technology," which ensures that the roller bearing assembly receives a constant flow of pressurized oil. This eliminates needle bearing oil starvation, historically a "problem area" for all solid roller lifters when used in low rpm and street applications.
My current setup has 220 lbs of pressure on the seat.
Lars
