DeeVeeEight
Fast Pedalphile
I have gotten my 383 running again after a bit of a scare. Now I have an intermittent smoke issue. Here's the scenario... No smoke on start up. No smoke on acceleration. No noticeable smoke while cruising but that is hard to tell with tinted windows and mirrors...
I do get smoke occasionally when the motor is hot and at idle. I was originally thinking a worn valve seal but that would give me some smoke on start up and possibly a fouled plug and/or misfire. Then I got to thinking maybe too much suction at the PCV valve so I pulled it out of the valve cover. The PCV valve was buzzing like a bee and had a lot of suction, it is plumbed directly into the base of my single plane intake manifold just under the carburetor. Is there a way to decrease the amount of vacuum there so I do not pull oil out of the motor and into the intake?
