We may lose some conventionally when we start dealing with higher grade materials, but Yes the conventional fastener would rival the TTY if it goes through the right preparation and is made from the right material. For your torque question about TTY torque methods, ARP does "not" use TTY material so most all of our kits will have a specific torque that will get our fasteners to the desired clamping force, and most TTY fasteners from the factory will have an angle or degree torque method to get to a desired fastener yield point and as I stated before the TTY fasteners are usually set up to its maximum clamping force when it reaches its full yield point so is does not have much more stretch available for Aluminum contraction or head lift caused by a Turbo or Supercharger.
For you second question here is a copy from our catalog that I hope will help:
The Stretch Factor
It is important to note that in order for a fastener to function properly it must be "stretched" a specific amount. The material's ability to "rebound" like a spring is what provides the clamping force. If you were to simply "finger-tighten" a bolt there would be no preload. However, when you apply torque or rotate a fastener a specific amount and stretch it, you will be applying clamping force. The amount of force or preload you can achieve from any bolt or stud depends on the material being used and its ductility, the heat treat, and the diameter of the fastener. Of course, every fastener has a "yield" point! The yield point or yield strength of a fastener is the point at which the fastener has been overtightened and stretched too much, and will not return to its original manufactured length. As a rule of thumb, if you measure a fastener and it is .001˝ (or more) longer than its original length it has been compromised and must be replaced.
Thanks,
Sam Benson
Quality and Customer Service Supervisor
ARP, (Automotive Racing Products)
