Assuming the CD is a fixed component then changing only the coil could help me in a few areas I think. I am working on this as I and would like anyone to chime in!
1) If a different coil had a higher number of turns this would increase the output proportionally. More turns increases the field so when broken the spark has more energy.
2) If a different coil has a better heat sink (more liquid material, better liquid material and/or external heat sink for the fluid to transfer the heat to) this coil could produce more spark under varying conditions. In my case the coil is in the stock location and generally coil but my engine compartment gets stupid hot.
3) Could there be some difference in the quality of the wire used in the coil that could result in more spark energy?
Researching this has been very annoying because no one compares them on the same scale. What I can tell you is any OEM part (Ford or GM) is going to be better made than almost anything aftermarket and have a very long life. The MSD Blaster 2 I have seems to have a 50/50 satisfaction/disatisfaction ratio...
I have had an MSD shock me so bad I almost needed to change my pants so I was "shocked" when I got off so easy!
Decades ago a friend of dubious distinction who had a bastard vette of a '61 front and '58 rear, he grabbed a plug wire not ONCE and got knock back in the bushes, but got up again and did it TWICE.....:flash:
I think a stock HEI is about best you can do for reliability, and at that, solder the coil connections on the terminals, where the Red/wh-yel wires are crimped...
your comment about turns on the coil is not necessarily the end of the story, there are obviously two set of windings on there, and the power of a breaker point is limited due to point life, there is a series resistor in there to limit the current, primarily to keep it running when the dwell changes due to wear or miss adjustment, to increase the number of turns on the secondary does not necessarily do much it will increase the VOLTAGE, but there is only so much power in the coil frame, that stored magnetic field has X amount of power in it, so the increase of voltage will mean a decrease in amps available...
An HEI for instance has all the dwell shit programed into the chip driving the coil, so even the series resistor is not there....much tighter operating parameters....
IMO, copper wire is copper wire, and so for any given gauge the resistance is the same, obviously inductance changes with the magnetic coupling and the way it's wound on what style of iron core....then the iron core composition can be a great effect on it too...
Lots of happy horse shit going on in that 'field'....so to speak, I used to do a fair amount of work in it, first as a TV man, then working in a small company making walk through metal detectors, and treasure finding stuff, like Mel Fishers gear on the Atocha .....our gear worked on pulse field, not RF...all switch like an ignition system, metals react very weirdly to pulse field electronics, not what we would expect at ALL.....
