Big Brakes and Brembo's on a C3
Finnaly got this project finished today. 13 inch Mercedes rotors and Viper Brembo 4 piston caliper with one off CNC brackets.
FRONT
REAR
Total cost?? and how much was extra for the drilling/slotting or was that a Merc item on them stock?? ]
just for the two fronts, as shown....
I have a figger in mind for my break point, but it's interesting just the same....
:thumbs:
I designed and made the brackets also mods to the hubs and rotors. It has taken me a while and the rear brakes were a packaging challenge. The parking brake caliper is actually a mechanical caliper, works with the standard Corvette cable.
Ok for the mech park brake. Tought it was a bit like Norval did with a master cylinder from a motorcycle activated from the hand brake inside the car in mind, didnt notice the clip for the cable right away.
Neat everything looks compact and tight. Again, nice work.
What size wheel will you fit over that?
I dont think standart rally wheel will fit huh?
I'm planning on 17" wheels in front and 18" in the back. I need 15 1/2" clearance in the front and 16 1/8" in the back. Got my fingers crossed that it will work out:noworry:
Damn, this is automotive porn! I like the small mechanical spot caliper, looks to be even smaller than the one i have from wilwood. Damn, I'm jealous...very jealous!
They look really good Larry. How are you going to treat them for rust/corrosion?
The rotors are plated but I suppose it's just a matter of time before they start rusting. You know what they say, rust never sleeps.
Yes you have to drill the rotors. I am using the original lug holes for the screws that hold the rotor on. You have to redrill the hub and turn down the OD also.
