BlackBetty
For some reason I bolted the spring up to the aluminum block mounts on the lower control arms and the spring is touching the engine cradle in the middle and the ends are touching the bottom of the shocks. I havent even tightened the 8" bolts up yet. I have it set on next to stiffest hole.I have tightened the ball joints to specs, but I havent shimmed and bolted the upper control arms. I couldnt find the torque specs on the front shocks either. Anyone got a guess?
