First post here..........
I just found this forum and thought it would be a good place for my project.
I've got a 68 non-numbers matching SBC with 4 speed, big cam and 3.08 gears (not a good combo).
So after burning up a clutch this summer I decided on an LS motor. Original plan was for a 5.7 LS1 motor, but it was looking more like a 6.0 was a better choice for hp upgrades. So I ended up with an Escalade 6.0 LQ9 motor and added LS1 intake/injectors, 02 vette Z06 exhaust and "winged" oil pan.
I only needed AC compressor and alternator, so I made my own brackets. Belt Goodyear 4060827, 6PK2100.
this is the result:
After going through the original wiring harness that was a mess, I ordered an aftermarket universal harness and mounted fuses, relays, grounding block, etc over the Vintage Air evaporator on the passenger side dash.
I've cleaned up the wiring a little more since this pic.
I also went to wan electric wiper door actuator since the 68 vacuum operated one never worked well anyway.
The game plan is to use the LQ9 mechanical fan, with an additional electric fan that's actuated by engine temp or AC compresor. The air tube from throttle body swing back and over the intake. I've made a fiberglass tube, but you can see the original foam form in the test fit below. I've also made a flat element air cleaner assembly out of fiberglass that will be over the intake and use the L88 hood air box.
I've got a Richmond 6 speed coming in this week. It has the 0.76 6th gear OD, so I thought it would be a good match for the 3.08 rear end.
this is the result:
