69427
- Joined
- Mar 30, 2008
- Messages
- 3,077
- Reaction score
- 38
Got the frame done as far as I could go prior to slipping under the body again. The front frame horns will be finished once the body is positioned.
Got the body sitting on the frame. The work right now involves shimming the body mounts, and cutting/modifying the front bumper brackets and lower radiator crossmember mounts. The sway bar sits higher than the previous C3 location, so that required modifications to the brackets. The steering column to steering rack linkage measurements are now possible to do.
The rear area looks basically okay, although there were a couple items that slowed me down. As I was lifting the frame up under the body, I saw that the batwing mounts were going to contact the bodywork in the rear compartment area. I dropped the frame back down, and did a bit of grinding, and things look okay there now. Tomorrow I need to run to the hardware store to pick up longer rear spring hanger bolts to drop the rear down a bit. Once I have everything sitting at the level I want I'll be able to doublecheck the suspension clearance issues (lock to lock, and bump/jounce). To my annoyance, I've misplaced my coilover adjustment tool, so I'll probably just make a quick rough copy to adjust the front suspension until I find it. Once I'm happy with the rear suspension stuff I'll pull out the set-up (lengthened) C3 halfshafts for narrowed C4 aluminum shafts.
