Hi Folks, I'm in need of a little help, and this should be the right place to ask I'm sure.
While cruising at 60 to 70 mph and hitting the gas, my 72 sb falls flat on it's face. A quick history, fresh complete rebuilt 350 (8000 miles), carb. fresh rebuild with a new float and accel pump two weeks old. Brand new fuel pump and rubber lines with new fuel filter at the carb. The old fuel pump failed, thought that this was the problem but it ran poorly today after the new pump was installed. It seems that heat might be part of the problem? In the morning it ran fine later in the day the stumble happened. The sock in the tank looks clean, and I have a vented locking gas cap. The motor is just not running the same?
Any help would be appreciated,
RPO LS5
RPO LS5
