I thought you guys might want to see what is probably one of the strongest IRS setups around. This setup is similar to Jim Moore's 67 Convertible assembly. I purchased the assembly two years ago from an NHRA class racer. I had planned to run the setup in my car, but life got in the way and I have sold my Corvette. I had the trailing arms and rearend rebuilt by Mike Dyer. The Crossmember Bushings, Trailing Arm Bushings, Trailing Arm Seals and Bearings have been replaced. The U-Joints are Spicer 1480 Non-Greasable units and are brand new. Almost all pieces are powder coated. The Dana 60 Unit is a spool with a 4.88:1 gear ratio. I don't think that you will find a stronger IRS setup than this. The assembly is ready to bolt in to any C2 or C3 chassis. I am asking $5100 OBO. If you want to run hard at the track with an IRS and not worry about the rear end, this is the kit for you.
Send me a PM or email if you are interested.
IMG]http://i295.photobucket.com/albums/mm136/vetmaniac1/dana60_front_2.jpg[/IMG]
