Richard454
For those of you that have messed w/ the "free" tool loan at the local Auto Parts place-and then had to purchase the tool because you destroyed the chinese junk- This ones for you!!!
If you have ever tried to replace an original or Big block spring -you know the headache of the threaded spring compressor-won't compress enough and then the "fingers" get caught between the coils and impossible to remove....
I knew there had to be a better way- The "J-22944"
After looking at it- Did a search and they were nowhere to be found.
Hence- the idea to make a "New and Improved" one-
I whipped this up at my buddies machine shop w/ some scrape metal laying around.
I improved it by adding a fitting that'll go right in a standard floor jack-
Here's what it'll look like in action-
Any interest? I can make several more. Price? It's got to be a lot quicker than the threaded spring compressor.
Ideas to improve it? I'd put a cut heater hose over the A-Arm cross shaft to protect the paint/powdercoating..
Richard
Richard
