Trying to adapt the C5 master cylinder to the C3 distribution block.
I need to make a short brake line with a bubble flare on one end and a double flare on the other end. I can buy a short length with the bubble flare already on it but the tube is 6mm (.236). So I can't really grip this tube with my double flare tool. To make this even more complex, I need to go from a 12mm x 1.5 bubble flare (rear port on C5 master) to a 1/8-27 NPT on a Wilwood adjustable valve. Then, the front port is 12mm x 1.0 and I need to go to an inverted flare with a 1/2 tube nut.
Any ideas? Is there an ISO bubble flare that uses a 1/4 inch line? Any other solutions (adapters etc)?
