greg75vette
The Traffic Baron
Yet another wiring question, bare with me...
As I was checking out how to wire up my start and alt, I took a good look at my wiring and I'm not sure it's in the best shape. The insulation is still flexible and isn't cracking. However, I have some things I'm not sure are repairable.
First up is one of my alt wires has a grinder burn (I did it...) through the insulation:
Can I throw some shrink wrap on it and call it a day?
Next up is a joint between my two alternator wires. It looks factory, but I kinda doubt it. The black on the insulation, I believe, is from the fabric like tape that covered the joint:
This normal and/or safe? Throw some tape or shrink wrap over it and call it?
Last up is my starter wiring. I have a bare spot in the purple wire and are the two reds supposed to be like that?
Can I throw some shrink wrap over it and call it?
The final question is where do you guys get your high quality ring terminals and crimpers? All I really have is the el cheapo types you can pick up anywhere.
I'm looking for honest opinions here. I would prefer not to replace the engine harness because the rest looks great, but if it isn't safe, then so be it. Thanks again for the help guys.
