6.2L all Aluminum Dry Sump.... HMMM
84rzv500r
Knows just enough to be dangerous!
Big Pine Key, FL
Now this puppy at 7 liters or 7.4 liters has some appeal... this one is 12.5:1 solid roller cam, and were gonna run run the dry sump setup that cam on it from the General and a MAST two piece ram manifold and a single venturi carb... oh and 250 shot in two stages, mated to a "powerglide"...
Are you going to run an SV1 carb? I have one too ;) :D Kind of a shame to run a dry sump motor with an automatic, it needs a stick shift :D
yep an SV1... with a MAST tunnel ram...its going in a tube chassis 1950 chevy drag car...
if it were mine id run more compression and hilborn with EFI or a Kinsler cross ram...
oh yeah and a ROD 6...
I'll post the Dyno results...
:sweat::sweat:
I chose a WCCH ported tall deck LS7 manifold because that Mast 2pc thing is super tall.
