63-82 parts
GTR1999
Gearhead
New Haven CT USA
For sale, new, never used. Price doesn't include shipping
Shock mounts, usa made $40 each
Steering Box master kits $70
Spicer Solid U-Joints $27 each
Headlight rebuild kit $80
SS rear shim kit $30
Differential Parts-Master kits, gears,etc
Trailing Arm parts - USA Timkens, shims, plates,etc
Gary, Is a steering box master kit everything you need to rebuild a C3 box?
Steering box master kits are what I use for my std rebuilds. Gears,cover, lock ring, nut,lash nut,or custom bushings are not includede.
They include:
new bearings and races
54 balls
cover gasket
Std bushings
shims
seals
end plug
nut & washer
Marc,
I have posi kits I put together for $185.
They have the solid steels, full shim kit, retainers, GM additive,steel washers.
I can sell the shim kits separately as well, they come in 005 increments from 010-045" for $32 .Custom ground shims are $4 each.
I just need clutches and shims. I already set up the entire diff but don't have steel clutches, just carbon junk and I'm lacking clutch shims, don't have enough of them.
005 increments are fine, I got the last one spot on with them also.
