redvetracr
the only requirement is you have to run a factory type dual plane intake and it has to live in a road race car, anything else goes, is 750-775hp possible? I have an itch.
Has to stay 427"?
Ive got a friend that ran an all aluminum 598" BBC... Made 1029HP N/A with a Lucas mech stack injection. Came out of his CanAm car. The extra cubes would help it live a little longer at that power level
Could the manifold be modified?
yes it can
Why not just put in an economical iron block 427 with aluminum heads and just go have fun?
"Anything else goes." Can you blow it? If so, I bet you can get it.
Buy one of these, and add a paxton with a hat.http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnumber=19166392
Damn, what are they paying the guys to assemble those things? That thing seems about $10k overpriced to me.
Yeh that was originally my thought. Way back in the early 70's my brother and I took his 390hp 427 and put these high compression TRW forged pistons in it. Reworked the Iron heads for clearance and flow. Put a Crane Fireball cam in it with specs similar to the L-88 ( I can't remember the specifics) along with triple valve springs. Put a tarantula intake manifold along with the Holley 750 douple pumper. The one with the carb positioned at a 45 deg angle for equal flow. 4:11 rear end. I don't know how much hp that thing had but it would rap up to 6500 in a blink of an eye. He turned in the mid 10's with it before he cratered the rear end. That's the same engine in it now. Had to burn avgas or racing fuel and still do even with FI.
So, Thinking along the lines you just suggested, I thought about some aluminum heads cc's to lower the CR to ~10.1. Hydraulic roller FI cam along with ditching the 4:11 rear for the original 3:08 and go have fun.
All aluminum short block just sounds more bling:quote:
Howard, 40-$45k??? Whats that? and old L-88?
Bling? We're talking functional aluminum, not chrome or carbon fiber overlays here.
True, but given the difference in the iron block vs aluminum and what I would use the car for, at this stage of my life, it would probably fall more in the "Bling" catagory. :waxer:![]()
