clutchdust
Millionaire Playboy
I picked up a used set of AFR 190 heads about a year ago for a really good deal. So as time and money permit I am working on putting them in my car. They were complete assemblies but I don't believe in just slapping on any used part, so I've disassembled them and had them checked just to make sure they're not cracked. Now I'm cleaning them up a little. They don't really have much to go but I'm just knocking down any casting flash and polishing the bowls as much as possible.
So anyway, the cam I have now is the Comp Cams Xtreme Energy 276 listed at 276 intake/282 exhaust. Lift is advertised at .502 and .510 with a 1.5 rocker. Before I reassemble these heads I'm planning on upgrading the springs a bit and switching to a 1.6 rocker to support the additional lift. The lift should put me in the .530-.540 range.
Since I really don't know the history of these heads I'm going to change the springs and seals anyway. My question revolves around capacity. I've heard these heads run out of steam at about .500" lift anyway. So even if that's true, is there a down side to switching to the 1.6 rockers and increasing that lift?
For what it's worth, the engine is a 90's truck roller block, +.030" with hyper pistons with a 3.5cc dome, should net me around 9.5-10:1SCR.
